2011 Chevy Tahoe “Tug issues”
petethepug
Michael
SoCal
What is typical for this Gen truck is the carbon fuel canister barrier breaks down and releases carbon pellets in the fuel system.
Replace the $100 canister. It’s least expensive on RockAuto or Amazon. Shake it after the 15 min process to replace it. You’ll see what’s likely floating around in your tank, fuel pump and evap system that needs to be blown out.
The total fix involves dropping fuel tank, replacing w/ OEM fuel pump (parts geek), evap purge valve @ fuel neck and the PCV valves on the left & right valve covers of the motor.
Consider this a 100k required service. The lower the fuel level. The more the pellets gather around the fuel pump to “tug” your fuel supply down.
The Grey Beast
The Grey Beast
Are you ready for this Lol. Turns out I don’t have transmission issue. The Tahoe was locked into 4x4 when it was on illumination on auto. That is why it had issues. I feel dumb but the mechanics that work for Chevy took awhile to figure it out. It was only trial and error that they finally figured it out. They too felt what I felt ,when driving, but it took some driving to feel it. I have to tell you it really did feel like a transmission issue. So far it works great.
I’m relieved even though a total failure of the transmission would have been paid for by the insurance. It’s. nice to know I didn’t buy a dud.
Again wasn’t here to waste anyone’s time. To including myself. I also wasn’t here to make anyone the fool. There is a lot of knowledge on this board. Thank you for all your help. This post should be used as a future reference. A future checklist to mark off.
With my luck this maybe a temp fix.
Until then thank you all.
Ken
NickTransmissions
Sin City
The transmission bench
Ken
Very interesting, and unexpected but glad you don't have a transmission issue! Don't think you wasted anyone's time at all; in fact thank you for following up, letting the board know what the problem/solution was (many don't).
petethepug
Michael
SoCal
This is a best case scenario win. Pretty funny to be on dry pavement in 4WD. That’s definitely a wtf is going on scenario.
The Grey Beast
The Grey Beast
Yeah it was odd. You think ‘if I just played with a few of the knobs and maybe it would have worked. Lol it did really feel like it was failing (transmission) what can you do except live and learn.
Thank you both.
Ken
The Grey Beast
The Grey Beast
So I had the transmission flushed and fluid replaced. So far I notice the difference. Hopefully the “tugging” will cease. In winter in California it’s less profound. Less “tugging “. Summer comes will see. That’s when the transmission heated up. So far got two new axel boots and axels. Thank you for all your help. Hopefully this helps and prolongs the transmission.
Ken
The Grey Beast
The Grey Beast
It’s been awhile on this post of ours but I wanted to reach out and thank you. I had the transmission flushed September-October and the “tugging” lessened greatly . Just had the transmission line changed and what a difference in temperature. In town it would be average 156-189. Prior to that in summer it hovered around 189-207. I will see if there is any “tugging” or “jerking”. Just had it fixed and just out of the shop. I thank you for your time and opinions. Raw knowledge and expertise. It’s not cheap having an older Tahoe but all your ideas help. Till the next problem.
Thank you
Ken
The Grey Beast
The Grey Beast
So I wanted to thank all of you. I had the transmission line replaced and what a difference. It seems that the line should have been the first thing to work on having my Tahoe a year ago as of May 8th. It needs a new oil cooler line and a bolt on the exhaust drivers side broke off. Both are on my list to replace. It cost money for an older SUV especially not having tools and experience. Well worth it though when considering new to used.
Aloha to all. Brothers and sisters.
Ken
Anothertahoe
