Glad it was much simpler. So, something broke or it just popped off? I don't see them just popping off unless something is worn or broken. It's be good to know so it doesn't happen again.
Driver's side, along the edge of the trans pan. Something like this:
That black metal "offset" piece is the arm that is moved by the cable to click the trans into gears. The cable on this one had come off and was repaired with a stainless bolt, nut and washers. I think it's on an SSR, but it's still a 4L60 (or 6L?) and will be similar to yours.
Here's a pic of a cable separated from the arm on a Camaro. Again, driver's side and similar to yours:
I can't tell you how many times I've seen this happen on newer jeeps...
Great minds think alike sir! lol5- or 6-speed manual swap would fix it!
makes me feel better as I have a 2012 4 door wrangler as well, I will be sure to put some zipties in the glove box
