2011 Yukon Denali- Air Ride Compressor constantly coming on/off
Denaliz
Frisco,TX
I am the original owner of my 2011 Yukon Denali with about 102k on the clock. I have noticed the air ride compressor is constantly coming on then off. I'm guessing this means I have a leak in a shock?
My question is where are you guys going to replace the air ride shocks on these? Should I look at replacing the compressor at the same time? It seems to be working just coming on way too much.
I did have the lower control arms replaced about 8 months ago.
sk1dm4rk
Chris,
I recommend finding the leak first. If it is in the shock (likely), then you will need to replace them.
I used Arnott and they have been great. Others have had issues. They are rebuilt/reconditioned with new air bladders and whatever.
Until you trace the leak and fix, I recommend pulling the fuse for the compressor so that the pump doesn't fail from all the running it is doing.
There are quite a few threads on here that can help you further.
Good luck.
Denaliz
Denaliz
Frisco,TX
I pulled the fuse already-thanks. First thing I thought of. I know with my Denali being 7 years old and 102k on the clock. Shocks are needed all around. I'm looking for the best priced option to do all 4.
FredEx112
