2012 Suburban..Heated steering wheel problem
Sweet Pete
Hello All,
I just bought a 2012 Suburban LTZ. The heated steering wheel isn’t working correctly. The button wouldn’t light when pressed and no heat on the wheel.
I checked fuse #48 and it’s good. Next I found the 7.5amp inline fuse under the dash, which was good too. After that I turned the key to accessory and the heated steering wheel functioned properly. However, when I turned the engine on the heated steering wheel stopped working. Even if I tried it with engine off the button again it still wouldn’t work.
I pulled the 7.5 amp fuse and reinserted it and once again the heated steering wheel functioned until I turned the engine on.
Does anyone have any suggestions on how to fix this? Thanks.
Hello All,
Welcome Pete, I'll take a look through the manual tomorrow and get back to you. Did it originally come with the heated wheel or did someone add it? Don't know the RPO off-hand but someone might.
Sweet Pete
Sweet Pete
Thanks for your help. I assume the headed steering wheel was factory installed, but I suppose I don’t know for sure.
St. Louis
The RPO codes concerning heated steering wheels are:
NR7 - leather wrapped
NSH - wood
N31
N57 - leather with adaptive cruise
UVD - switch steerinv wheel, heated
2001 Yukon SLT
2012 Yukon Denali XL
2011 Yukon Denali RIP 5/20/18
Sweet Pete
Sweet Pete
Thanks for the RPO codes. My truck has a NP5 instead, which best I know is “leather wrapped.” That means the heated steering wheel was added by a previous owner?
wjburken
Eastern Iowa
On my 2013 Yukon XL Denali, N30 is leather wrapped steering wheel and UVD is Heated Steering Wheel.
The LTZs had an all leather heated wheel whereas the Denali and Escalade had wheels with wood trim, different RPO codes. I think you might have something like KA9. Anyhow, if you want the wiring diagram, send me an email.
St. Louis
I don't have any of those RPO codes I listed above on my 2012 Denali. I do have KA9 and N30, but no UVD.
I did miss KA9 on my original list because it's listed as "heater steering wheel" and not "heated" on the RPO list sheet I searched... Lol
N30 is Sterring Wheel Deluxe
2001 Yukon SLT
tators50
