skpyle
- Joined
- May 15, 2021
- Posts
- 412
- Reaction score
- 1,081
Hello Gentlemen,
Well, the honeymoon is over with my 2013 Escalade ESV Premium. Last night, the check engine light came on. This morning, coming out of work, the remote start didn't work.
Once home, I dug out my neanderthal scanners and pulled codes. I have the following DTC's stored:
P0131 (scanner called it 'O2 sensor circuit low voltage bank 1 sensor 1') Alldata calls it 'HO2S Circuit Low Voltage Bank 1 Sensor 1'
P0171 (scanner called it ' System too lean bank 1') Alldata calls it 'Fuel Trim System Lean Bank 1'
NOTE: I did not 'feel' the check engine light come on. I just happened to look down and see it on. The vehicle drove fine (no different than my limited 5 days of driving) last night and this morning.
Also, this Escalade is a Flex-Fuel model.
I have done some quickie google-fu and general consensus is:
P0131 is likely a failing bank 1 primary O2 sensor
P0171 is likely an air leak.
However...according to Alldata, conditions for setting P0171 include P0131 NOT being set. Meaning two different issues? I had been caught in the 'chicken or egg' mentality. Meaning, was I seeing codes for a failing O2 sensor, or is the O2 sensor reacting properly to an air leak?
I used both scanners to pull some live data at idle. NOTE: I have a clone Tech 2 on order, but it likely won't be here for another week.
FRP(psi) 43.1-43.9
ST FTRM1(%) -0.8 to -2.3
LT FTRM1 (%) 2.3
ST FTRM2 (%) -1.6 to 0.0
LT FTRM2 (%) 2.3
O2S11 (V) 0.100 to 0.750
O2S12 (V) 0.645 to 0.670
Looking at Alldata:
P0131 is set when the HO2S voltage drops below 0.050V. Looking at what I believe are my primary O2 sensors, neither is below 0.100V. However, note how sensor 1 varies while sensor 2 is relatively steady.
P0171 is set when the long fuel trim for bank 1 is greater or less than a calibrated value. I sorta got lost looking at that one. I did note that both long fuel trims were stable at 2.3%. However, short term fuel trim 1 was acting rich(?) while short term fuel trim 2 was acting a little less rich(?) Rich meaning negative value is the ECM pulling fuel.
I have searched the 2007-2014 forum, did not really find much for both P0131 and P0171. Hence my post.
I am writing to see if anyone has any insight?
I am on a crunch because I should have been in bed hours ago. To get up this afternoon to go to work. I have to go to work tonight, and Sunday night. Monday morning, I am off for a week.
My intent right now is this:
-tonight, clear the codes before I drive to work. See what happens.
-Monday and Tuesday, perform the transmission work I had scheduled, because I will be replacing both primary O2 sensors with GM Genuine 2133866 units as part of it. After the transmission adapts are relearned, I will see how the Escalade drives on the way home, and see if the P0131 and P0171 return.
And troubleshoot accordingly.
Thanks for listening!
P.S. I learned in the owner's manual that the remote start will not function if the check engine light is on. Good to know...
FRP(psi) 43.1-43.9
LT FTRM1 (%) 2.3
LT FTRM2 (%) 2.3
Looking at Alldata:
