2013 Yukon Denali Express Power Windows?
Blazed
Accepting Donations
Sometimes you get negative posts like that as if it really affects the forum to have two of the same question. Ignore it. You'll find your group of friends here.
morriskb
Missouri
Has anybody been able to successfully install the power window switches with express-up from the 10-14 escalade into a Denali? The part number I've found is 20980437
The plugs appear to be identical and should go right in and fit. Assuming yes, would I also need to replace the switch on the passenger side as well for that to work?
Shadfrmdabull
