2014 Yukon factory backup camera wires??
93-306
I just put a double din navi in my wife's 2014 Yukon with a factory backup camera. Is there somewhere I can tap into the rear view backup camera to get it on the aftermarket navigation screen. Location and wire colors would be great. Thanks in advance!!
NathanJax
Vacation Nathan
Administrator
Jax, Fl
Depending on the wiring harness you have it's built in to the harness and the wiring gives you an RCA input
93-306
Mine didn't have a factory navi so I can't just plug it in. Trying to see if their is anywhere I can tap into the factory feed
Adam Ostrowski
I have the same year and what I did was went up to the connection that is on the rearview mirror.
It was the blue and white wire that is next to each other. i pealed back the coating and soldered it to make it solid.
I ran a wire from the mirror above the headliner and down the A pillar.
After that it is just connecting it to the radio.
I spent a lot of time researching and didn't get any real good leads on where the best connection was.
This was what i got to work.
With doing this both monitors showed the image
Smityinms
