Yes 3.42 gears and yours is set up for maximum towing. It also has the 2-speed transfer case and the external transmission and engine oil coolers and 700 watt cooling fans.I just ran outside to check my glovebox, and this is what I see...
Fourth row down, fourth column over: I see GU6 listed. So that means I have the 3.42 final drive ratios, right?
6PB and 7PB are your front spring codes.
So, now that we know what your gear ratio is, your rpms are about 75 rpms lower than with the original tires (1626 vs 1698 (mathematically)). The tune will certainly wake up the truck and greatly improve transmission performance and likely will quell your desire for a lower ratio gear set... for a while anyway!
