16blkltz
- Joined
- Jan 17, 2017
- Posts
- 279
- Reaction score
- 221
Thanks. Not too worried, but if I run into anything, I'll be sure to hit you up.
16blkltz, your dealership actually installed the lowering springs? Interesting. I saw a YouTube video where I believe the ball socket ends just pop off, or at least that's what it looked like. Looks like the new rods are threaded on both ends. I'm guessing you twist off the ends and put on the shorter bar.
Yes. I had the dealership's service dept. order the kit and install it. I know I probably paid WAY more than what local shops would've charged, but I wanted it that way for alignment and warranty purposes. Actually, they were only approx. $150 more than 2 local shops I got estimates from.
As for my rods, I later replaced them with fully threaded rods I got from NorcalSS (Tony). I figured out a way of popping off the ball socket ends. I can't explain the details of what I did (I'll try to take pictures of what I did the next time I have to work on the suspension)...but you just have to clamp/hold the OEM rod and CAREFULLY pry or pull off the ball socket ends off. I did not have to twist while pulling.
