2015 Suburban: Exterior Pillar Covers Popping Off
hundhaus
Wyckoff NJ
both my 15 Denali and my Denali XL have this issue. Dealer claims its only my two trucks.
fiatdale
Houstons Best
Houston
This tape is used across every manufacturer everywhere for trim, body moldings, emblems etc. Its not a GM **** up - more so probably uncleaned panel before they stuck it on.
hundhaus
Wyckoff NJ
You kinda just contradicted yourself
fiatdale
Houstons Best
Houston
Im saying its not just a GM **** up - everyone uses the same spec of double sided tape. Happens to all manufacturers.
ktrent
My drivers side can of. It's not 3m tape holding them on fiatdale that's failing it's the threaded clips that are heat pressed onto the panel that's popping loose. This happens when cars are made from aluminum and plastic instead of steal. Lol
Sent into space with tapatalk
mrhs
This happened to my passenger panels. My dealer said this is a known issue and that they have a redesigned panel. Dealer fixed mine. YMMV.
Illnasty
New Jersey
Good to know. I had a deep scratch in on of mine and the dealer replaced it. I figure that these will get those beautiful swirl marks after a couple of washes so had them wrapped in clear Xpel but thinking I should have gone with a matte black.
tdowns12
After a week or so my double sided tape solution failed again. My Yukon is in the shop now and the dealer was very aware of the issue.
hosseface
Silicone them on. I did that with my 15 and they held fine. Problem solved with no opportunity for the dealer to cause additional problems.
fieldgoal00
my wifes 2015.5 yukon has the same problem. both the driver door and driver side passenger door come apart. Driving 85 in TX and i thought they were gonna get ripped off. Have they come up with an actual fix?
eb5665
