2015 Tahoe Help Needed!!
Ltsheets
Hi everyone! I’m having very odd issues with my 2015 Tahoe. Here is a list of what is happened…
- Service Brake Assist warning (I haven’t had the recall done and plan to)
- Cruise control will turn off with turn signals at times
- Stabilitrack Warning followed by stiff steering
- Airbag light lit up momentarily
- Occasionally the back up camera doesn’t work
- Car turned off 3 times while turning sharply at (luckily) slow speed
There will be days that go by that none of these happen and then one will. I’m hoping someone on here has already seen these and has an idea about a fix. I want to try and avoid dropping it off at a dealer with them having to start from scratch with troubleshooting. Thanks.
Prospect62
Central NYS
I've never seen an instance where all of these same failures occur at once, but I'm guessing it's something electrical inside your column? Almost every item on that list is wired through the steering column.
exp500
Sounds dangerous! Have it scanned on test drive. Recommend factory fault diagnosis chart for codes.
Thats to start to figure it out. Keep posting results.
(That steering issue sounds like brakes were applied at the time.)
L
Ltsheets
Thanks guys, I’ll keep you posted.
this all didn’t happen at once. It’s a compilation of things that have happened over the past few months.
Carlos Ruiz
mine is a 15 tahoe ltz and the dealership ended up replacing the negative cable harness. i also replaced the battery and been good since. I've dealt with this electrical gremlin for a while as well.
L
Ltsheets
Thanks for this. I think I’ll get a new battery for it and when I take it to the dealer, ask them to do the recalls and put a new neg cable batt harness and see if that helps.
Babadook76
