2015 Tahoe/ Yukon Train Horns
Lurch
No problem.... if yall want any more pictures just let me know.
Yes, please! Weather is starting to warm up and I can get this mod done. Good idea on the compressor location. What's the set up on the inside? Do you switch between the normal horn to the truck horn via relay or is it a separate switch?
Any recommendations? I've wanted to do this for a while and wanted to put some Kl5a Nathans on but considered one of the kits instead because its all included. I just wonder about the sound difference.
tdriver113
Illinois
Any info on the compressor install would be very appreciated. I had shockers on my previous vehicle, and a mount for NATHAN K and P series horns. Of course that was on a pickup truck..............
08grey
It all depends on the horn. Some you can get away with 1)4 hose. Nathan's you need a larger hose and tank. I have a fire truck horn and I love it. What horn are you considering?
Pockets
West Ga
Sorry guys It's been a while since I've been on here. This is my ex wife's ride now but I'll get some pics asap...
Sent from my V10 using Tapacrap
RichardCranium
Mebane, North Carolina
I will be installing my Nathan P3's (real train horns, not the plastic ones) on my 2007 Tahoe in the next couple of weeks. I've had this entire setup on 4 different vehicles ('08 Tundra, 06' white TBSS, '08 Denali pickup, and '06 blue TBSS), so the Tahoe will be the 5th. The easiest thing to do is remove the spare tire and all the associated hardware. With that stuff gone, there is plenty of real estate to mount your hardware.
My setup are the horns (Nathan P3), a 5 gallon Hornblasters 8 port tank, Vaair compressor, and a SMC nickel plated valve. All of this stuff fits with no issue with the spare removed on all 4 previous vehicles. I use 18ga angle iron to help support the larger stuff, usually routing it through and/or bolting it to existing chassis points that are drilled by the factory or by me. Mind you, the zip ties you see in my photo are not what support the hardware, they are took take a little shake or play out of the horns and other pieces to keep them from moving around too much.
Here is a video of the Nathan's in action on my Denali.
clarkely
I have Leslie rs3k on my duramax..... I use a graham white metered train horn valve..... great for feathering the sound in and out ...may have to add them to the wife's hoe ....but I hate giving spare up
Sent from my SM-N920T using Tapatalk
clarkely
Some clips of my horns
CaliCrusin
