2016 Denali XL - GMC Refused to buyback!
ajs800
Michigan
when testing, put it in M5 to avoid the V4 mode and see what the results are. If there's buffeting and/or vibrations, you know it's not V4 related. I would like to think a dealer would know better, but I've learned they don't have a clue sometimes regardless of all good intentions. I'm certain the vibrations will be less without V4, but guessing the buffeting will still be present.
T
tenbigblinds
My advisor just called. He definitely felt the pressure (frequency) and they engaged the GM engineering team. The team asked them to leave some form of valve open and try it. He said the pressure was gone when they tested it. GM engineers told them to replace the exhaust system.
ajs800
Michigan
Curious if this cures buffeting/pressure feeling. Most with buffeting experience in v4 as well as other times.
Hopefully in your case it is only when in V4 mode.
T
tenbigblinds
It's what the GM Engineers advised. They are leaving the valve open, new exhaust system arrives on Tuesday.
My concern is I took it in for the 3rd time for "low speed vibration". They wouldn't acknowledge that but did say when they test drove they noticed droning/pressure.
I will update again when I get it back with the open valve and again after they replace
Exhaust.
ceramicdds
