2016 Tahoe LTZ Transmission issue (P0741 Code)
jrmhokie
New member, apologies if there is already a thread on this but couldn't find it. 2016 Tahoe LTZ w/ roughly 130k miles, owned since 18k miles. Yesterday on the way home from the airport I noticed the transmission was acting differently. Check engine light came on so I pulled over and used my OBD2 scanner to read the warning light code. Came back as a P0741 "Torque Converter Clutch Circuit Performance/Stuck Off". The transmission performance issue I was seeing included (1) felt like it wasn't making it to 6th gear at highway speed (at 70mph is was running at or above 2500rpm) and (2) once I got off the highway I noticed that the car would not shift properly from a stop, with RPMs going well above normal before the car would shift gears. I took it to a local transmission shop this morning and where the technician hooked the shop scanner on and drove it around (with me in the car) for about 20mins before heading back to the shop where he said that he thought the best course of action would be to replace the transmission (am currently waiting on estimate). I'm no transmission expert so I'm looking for some additional brain power on what realistically is wrong and what a reasonable fix would be for this issue. @NickTransmissions any advice would be appreciated. Thanks in advance for your help.
Welcome to the Forum from NH.
Pics of the truck, please.
I cannot personally assist you with your issue, but Nick and other members of this Forum much more knowledgeable than me in this area will chime in.
J
jrmhokie
J
jrmhokie
okie dokie. pics to follow
NickTransmissions
Sin City
The transmission bench
P0741 is usually converter failure and converter failure usually equates to transmission failure, unfortunately.
Reasonable (and correct, sustainable) fix is to properly overhaul the unit and install an upgraded converter with a better clutch. Also flip the pill inside your thermal bypass valve.
While the factory TC is a POS, there's quite a few upstream drivers behind its frequent failures including worn TCC regulator valve (valve body), worn pressure regulator valve (pump), bad TEHCM (not as common as the previous two), excessive trans temps (moreso w/the K2 trucks/SUVs 2014+). Visit my 6L80 Info Thread for more details on these units - link is in my signature line.
J
jrmhokie
Thanks @NickTransmissions for the detailed response. Transmission shop said about the same thing and they told me they use an upgraded converter when they swap in a rebuilt transmission. They rebuild the TEHCM in their shop and end up replacing all the valves. I'll double check the when I drop the Hoe off this afternoon and will ask them about "flipping the pill". Appreciate your help.
NickTransmissions
Sin City
Ask them for specifics around 'rebuilding the TEHCM' as they ARE NOT REBUILDABLE! The pressure switch seals, diaphragms and TEHCM filter screen are all replaced during a service but the individual variable force solenoids are not individually replaceable. I'd want to know exactly what they mean by 'rebuilding the TEHCM'.
Valve body/pump/center support should have a Sonnax zip or Transgo Tow-N-Pro installed. Pump should be replaced with OEM GM new assembly or reman'ed completely, down to the stator-stator support gasket.
J
jrmhokie
Sorry I misused the term "rebuild" on the TEHCM. They did exactly what you pointed out - replaced the seals, diaphragms, and the filter screen. Rebuilt transmission with heavy duty converter, rebuilt pump and they installed an upgraded cooler bypass valve. All in the bill was $5433. They also reprogrammed the transmission controller to disable AFM. Ran great when I took it home - but then he next day upon start up it was missing and threw a P0306 code which is misfire in cylinder 6. I spent some time this weekend swapping plug, plug wire and then coil pack between cylinder 4 and 6 to see if the misfire moved and it didn't. Next step is to take it to the shop to see if its injector related or lifter failure. I'm struggling a bit as it just seems too coincidental that the P0306 code popped up right after the controller upgrade..... any thoughts?
NickTransmissions
Sin City
No thoughts beyond taking it back to the shop to have them fix it, if they caused the problem. If they didn't (or if them simply disabling the AFM resulted in lifter failure), it will need to be fixed one way or another (if it's your lifter and not an injector). I think some scan tools can perform injector balance tests, not sure which one but if you have a bidirectional scan tool, check it to see if you can do that with yours. I'd rather diagnose it myself than take it anywhere. At least you know for sure (assuming you do it correctly) what the problem is vs relying on someone else who may or may not be honest w/you.
fullcourt24
