2016YukonDenaliGM
North MS
Hello all,
I have a 2016 Yukon Denali with the cooled seat option. I've owned the truck a little over a month now and I absolutley love it. It's comfortable, quick, and fun to drive. Today I noticed though that the upper portion of my drivers side seat was not cooling. The bottom half of the seat does just fine after a few minutes of operation on the high setting. The seats are perforated on the top and bottom cushions as well as the side bolsters.
It seems I may have 2 problems here.
1 - The upper half of my drivers seat doesn't cool now.
2 - The seats only cool after a few minutes of operation with very little pressure. (I've noticed others talk about how loud their systems are. Mine is very quiet and I barely hear it running at idle.)
The A/C will freeze you out in the rest of the truck front and back. So I'd say it works well. Does anyone have a diagnosis tree or link to a service or repair procedure for these seats? I cannot seem to find much on the 2015-2016 cooled seats. Only earlier models or the later ventilated seats in the 17+ model years.
Thanks in advance for your help.
Big Mama
Virginia
Welcome to the forum from Virginia. The “cooled” part of the seat is just air from the blower so it takes a minute to get there. Most makes are now calling them ventilated which makes more sense. I had a 2014 Sierra with the same issue. Does the heat work on the back section? Mine didn’t. I don’t have a fix for this as I sold the truck There may be a TSB for this. Hopefully someone with experience in this will chime in.
Smokin Denali
The way seats eork is by simple Air Circulation....not chilling the seats by extra equipment. It's just a blower motor that needs cold/ cooler air than dash level.....so your A/C must have already cooled the cabin air for seats to " grab" and circulate thru the seat.
As for upper NOT cooling I only see 2 possibilities...blocked/disconncted upper tube/hose or upper blower ( IF there are 2 separate) isn't working...electric or Mechanical failure..
My 2015 Denali w factory Cooled Seats ARE noticeabley NOISEY!. I change from HI to LOW speed asap.....
Take a look w bright flashlite under seat to start....I suspect there's only 1 blower but NOT CERTAIN.
Best wishes!
Big Mama
Virginia
Thus car makers changed the term to ventilated seats versus cooled seats.
Dremar79
