PA-WOODCHUCK
- Joined
- Jul 20, 2019
- Posts
- 63
- Reaction score
- 21
Anyone know the AC delco OEM battery group, CCA, and AGM or not? I'am trying to avoid almost pulling it out to get info... so I can properly test it?
thanks
thanks
should be a H7 800-1000ccaAnyone know the AC delco OEM battery group, CCA, and AGM or not? I'am trying to avoid almost pulling it out to get info... so I can properly test it?
thanks
It's an H7 like @Doubeleive said. Everstart Maxx is the same battery as the oem ACDelco. It's cheaper than the parts store as well.Anyone know the AC delco OEM battery group, CCA, and AGM or not? I'am trying to avoid almost pulling it out to get info... so I can properly test it?
thanks
I'm sure it's a good battery, but not $350Buy a good battery. Here’s what you need.
Battery Search | ODYSSEY® Battery
Use our Battery Search tool to find the right ODYSSEY® battery for your car, truck or powersports vehicle. Choose from a wide range of options in our Performance Series, Extreme Series and Pro Series categories.www.odysseybattery.com
Costco sell's the Interstate AGM's for right around $160-180.00 I have 2 in mine and they just outlasted the Odyssey's I used to use for twice the priceHere's what I found group 94R and H7 for AGM. That said if mine is 94R it tests good, but with AGM setting shows replace. I did both set to 800CCA. Standing voltage is 12.7v
Here’s where I buy them. They’re not good. They’re the best. $250. And free shipping.I'm sure it's a good battery, but not $350
