2017 Denali..Service Trailer Brake System
Blackcar
Today after filling fuel tank started up truck drove a little ways and Service Trailer Brake System? Haven't use system and truck only has 14000 mile 2017 Denali.
Still under warranty? Check the connector next to the hitch, you can unplug it from underneath and clean out all the dirt/dust. If you have an advanced scan tool, you can pull up the code that triggered the message. Somewhere underneath is the solid state relay (SSR) and trailer brake control module (TBCM) which interact with the BCM, ECM and EBCM (brakes). Check the connectors on those if you can find them. On my generation, they were not where the manuals said they would be. The SSR turned out to be in front of the fuel tank and the TBCM mounted on the driver's side frame rail.
Blackcar
Blackcar
Went to dealer battery voltage low they replaced battery haven't seen message since. Two year old battery !
It happens, and when they start to go bad they can wreak havoc on the electrical system setting off all kinds of false alarms. Mine is just over three years old and has been a little low lately too. Have a coupon for a new one...
2015 Denali here. I was getting the alarm on remote starts and periodic harassment on the Service Trailer Brake System. The final straw was that it wouldn't start after sitting for a week.
I replaced the battery. The alarm issue is gone. It's been a week. I had one STBS message right after but haven't seen it since. It seemed to do it more when it was wet out.
gsd1019
These trucks have an enormous parasitic load on the battery when parked. Battery tender all the way!
The battery didn’t fix my issue.
I’m about to go on a road trip this weekend. I didn’t bring it in to get repaired yet.
Every now and then - I get harassed with the warning. I get the warning ding and then the error clears - but this repeats every 30-60 seconds. It happened towards the end of my NY to NJ drive and didn’t not stop. Luckily it was 15 min from the destination. Today it started happening on my way home from work - good thing it was 5 min away. I’m crossing my fingers that it doesn’t happen on my 5 hour trip to Vermont.
Are there any temporary work arounds? Can I pull a fuse or disable it somehow?
JML07denali
What was the outcome on this?
In my case, nothing.
I took it to my mechanic. I believe a control module should be replaced to fix, but it would be expensive. They saw something about taking it apart, blowing out all debris and putting dielectric grease in. They tried it. It didn't seem to help right away. Then the issue stopped. I haven't seen this warning for the longest time.
Except I go and tow a trailer the other day. Now I'm getting this warning every now and then.
I'm thinking it may have something to do with the electric hookup by the trailer hitch.
lbenson
I had a similar or same issue a couple years back... constantly alerting me on a 1200 mile road trip to service trailer brake controller. I honestly cannot remember if we ever fixed it or not... but the quote was like $1000 something to replace the faulty electronic causing it. Either way it happened again briefly a few weeks back and haven't seen it since.
Regulator23
