andrewwest
- Joined
- Sep 19, 2023
- Posts
- 4
- Reaction score
- 2
I need some help, I have a 2017 yukon xl, having issues with the push button start, nothing light up and won't start. Can someone please help
check the battery and battery cablesI need some help, I have a 2017 yukon xl, having issues with the push button start, nothing light up and won't start. Can someone please help
All battery cables good. No corrosion on terminal, could it be a fuse??check the battery and battery cables
battery cables can corrode on the inside, I would use a meter and start checking voltages, if you blew a big fuse it would be one of the ones on top of the battery and those are not visible to check, you need a basic multi meter.All battery cables good. No corrosion on terminal, could it be a fuse??
What is the voltage of the battery when you attach the leads of your voltmeter to the terminals?I need some help, I have a 2017 yukon xl, having issues with the push button start, nothing light up and won't start. Can someone please help
Moved you here from 2007-14 section.I need some help, I have a 2017 yukon xl, having issues with the push button start, nothing light up and won't start. Can someone please help
