Kpwweb
- Joined
- Dec 11, 2015
- Posts
- 733
- Reaction score
- 330
If you're into off-roading, another down side you may want to think about is the LT does not have front tow hooks, the Z71 does. With that being said you can replace the front valence and add the hooks to make it look factory. This is what I did on my LT w/ max trailering pkg.
I did the same thing! Relatively easy mod for not much $$$.
You can also add the aluminum skidplates--a bolt-in process (with a few M-10x1.5 - 25mm bolts).
