2019 yukon xl 5.3 2wd has constant misfire on cylinder 7
so i diag'd a collapsed cylinder 7 afm lifter. also have a broken spring on a different cylinder - but not misfiring
im going to be replacing this at home
can someone check my parts list please and let me know if i need anything else
-headgasket
-valve cover gasket
-exhaust maifold gasket (head and y-pipe)
-intake manifold gaskets (8)
-afm lifter (4)
-lifter cup (2)
-headbolt set
-high pressure fuel line set (2pc's)
-intake valve spring
-push rod (4)
-oil
-oiil filter
-coolant
-headgasket
-valve cover gasket
-afm lifter (4)
-lifter cup (2)
-headbolt set
-push rod (4)
-oil
-oiil filter
-coolant
