2021 Tahoe Z71 Rough Country says no to 2" lift
JR09country
Z71 and at4s do not get lifts. The height comes from bigger tires alone. I'd bet money the front suspension on the SUVs matches the trucks, if I had a none air ride z71 I'd get the trailboss "lift" to get the longer cvs and a little higher ride height. Tons of companies making UCAs for the Silverado and sierras, just use those if you are worried about the UCAs failing.
olyelr
Elk Rapids, MI
The tires are the same overall size on the at4 and z71’s as any of the other higher end models (with 20’s and 22’s). The ones with 18’s have a smaller overall diameter though.
R32driver
Pretty sure uca failure on these suvs after a leveling kit install is all rumor and hearsay at this point. Those silverados/sierras were failing after a level kit was installed in addition to the factory lift so 4” lift on stock uca
sanman28
This. It was one persons claim and they sourced sierra/silverados as evidence.
Kpwweb
That wouldbe incorrect. The Z71s have 275/60r20. All other models have the 275/55r20 or 285/45r22. Diameters are different.
R32driver
Where did you even find those tire sizes listed? Everything I've seen shows standard tires on these new rigs as either 275/60/r20 (that's what came on our '21 slt) or 275/50/r22
olyelr
Elk Rapids, MI
Exactly. They dont sell them with the 285/45/22 anymore. They are 275/50/22, which is basically the same as 275/60/20.
Fireslayer308
So I spoke to RC Tech because their site says the 2" lift doesn't fit the 2021 Z71. He said it will fit but it's not recommended because the Z71 is already lifted and it will raise it too much without other changes which could damage the drive train.
I think their just trying to not have any issues with consumers who didn't realize the Z71 is already high. I would really like to see a Tahoe Z71 with the 2" lift because I want to upgrade to larger aftermarket wheels and tires. Any pictures of an 2" RC kit on a Z71 Tahoe 2021. No air lift suspension.
The Z71 does not come anymore lifted then the other trim levels. I have the RC 2" lift on my 2021 Z71 and have had zero issues. Also added some wheel spacers to give the stance I was looking for along with larger Nitto tires. Minor plastic trimming was needed to the fender wall to accommodate my changes. Currently have 12k miles with this lift installed and it rides great.
Safetypup
