2022 speed limit blank
Dustindu4
Salem, NH
I've got a 2022 Yukon and the speed limit on the HUD has always been blank. I have the full onstar and data package enabled and it doesn't work. What am I missing?
Blueinterceptor
Have you tried to center the display? Or gone through the menu for the display options
CoryS
Has anyone figured out how to fix the missing speed limit number in the HUD and instrument cluster on a 2022 Yukon? I am having the same issue. It just shows a white speed limit sign with no numbers. Thanks.
NathanSMSU
Had same thing occur on my 2022 highcountry. I found this in the owners manual - "Speed Sign : Shows sign information, which comes from a roadway database in the onboard navigation system, if equipped. The sign will show “− −” when offline maps are unavailable". If you go into Google Maps...settings...you should see something on downloading offline maps. After this mine showed backup. Interesting side note...if you have multiple profiles (like husband/wife) you will have to download the offline maps for each profile.
D
Dustindu4
Salem, NH
I called onstar and was transferred to tech support. Tech support said I needed to be transferred to GM and then onstar hung up on me. Then like 3 days later it started working on its own. Most of the time.
CMoore711
60% of the time it works 100% of the time
bam01
Same here it works one drive then another it doesn’t…
Dewally
Alabama
Same issue here. I did not give Google permissions for my location. I use Apple CarPlay. I have been wondering if that may be the cause of the issue.
Sven-from-sweden
