2022 Tahoe Z71 with Nitto Recon 285/60R20's installed
CBDFW1984
Burleson Texas
I can't find the post but wanted to follow up- Here are the after photos of the 2022 Tahoe Z71 with 285/60R20's NITTO Recon grappler's installed.
No rub, no problem at all. Looks much more aggressive than the Goodyears that were on it. No road noise from what I can tell either.
R32driver
Looks great! I’ve ran several sets of duratracs in the past (they get loud) but put a set of nitto ridge grapplers on our Yukon and they are great so far. Very quiet and smooth for how aggressive they are
sanman28
I bought mine in February 2022 and it came level.
It might be “level” but no GM SUV discussed here, absent air-ride, comes with a lift or level or anything different than the others. GM does not apply the sierra/Silverado AT4/trail boss formula it uses on the trucks….to the SUV’s.
CBDFW1984
CBDFW1984
Burleson Texas
It sits and rides 100% level. After purchasing I measured the ride height, front and back- It does not have the "air ride" system but does have "Premium Smooth Ride suspension uses a conventional Coil Spring suspension in the front axle, while the rear axle uses a self-contained, self-leveling Nivomat shock."
So, it sits level, however it is "STOCK".
sanman28
Well u got a good one then. Looks sharp. Most all show slight rake in the front of less than 2 inches no matter how equipped. This is for hauling and headlight reasons.
CBDFW1984
CBDFW1984
Burleson Texas
I made the change from a 6” lifted 2021 titan pro4x. This has been a great transition- I couldn’t be happier.
From the 2022 Z71’s I looked at, I didn’t notice a rake at all.
Tahoe4neutrals
