2022 Yukon XL Camper Towing
Cop35758
Hey folks,
I'm currently trying to order a Yukon XL SLT, 4x4 with Max Tow. In the next year or so, I plan to use it to pull a travel trailer / camper (maybe around 6000lbs dry). My biggest concern that I've been reading about is the amount of sag even with a weight distribution hitch. I would love to go with air ride suspension but that's a significant increase from the SLT. I would app any insight on what your towing with your SLT 5.3 and the amount of sag occurring.
Thanks!
Ungawa
Sorry but I have yet to tow with short 22 Yukon, but what your concerned about is tung weight And using a weight distribution hitch should correct most sagging.
WVBKW
I believe air suspension is critical when towing with these SUV’s. Have you considered a Suburban Z71. The pricing is in same ballpark I believe as an Slt and you can get air suspension.
The only time I have towed 6000, was my heavy equipment trailer with 2 sxs’s. Plus 5 people (610#)in the suburban. The Air suspension handled it perfectly. The 5.3 with Max Tow pkg was ok… but didn’t love the weight on hills.
I have since ordered a 2023 Suburban Z71 with 6.2 (don’t have it yet)and sold my equipment trailer and purchased an aluminum trailer weighing 1200# less.
suterusu
If you can get air ride, get it. Weight distributing hitch helps, but the air ride is the only way to really do anything about it.
az26er
I was able to get into a 22 Tahoe LT, Duramax with Max Tow using a Husky WDH and am pulling a travel trailer coming in just under 8000# and just under 30' in length so I'm maxing out the rating. Pulling out of Denver into the mountains on I-70 isn't giving me any headaches but I am typically staying in the right lane taking it easy around 45-55 MPH when I can. If I had the option to get the Air Suspension I would definitely want it but overall I don't think the sag is too bad with the WDH setup correctly.
Below is a photo of my setup ready to go to see the amount of sag on the rear.
crankin
I have a 2022 Yukon XL Denali with the 6.2
No max tow
No air ride just the magnetic suspension
towing a 32' Travel trailer weighing about 7200 lbs. I use a Husky TS centerline weight distribution hitch. 1 inch sag in the back and 1/8 to 1/4 raise in the front.
Just towed it round trip of 700km and I didnt have any issues
The level looks pretty good in that pic. If anything, I'd want the trailer tongue to be slightly lower in order to prevent excessive sway. I wouldn't want it any higher.
ehernande86
