2024 Yukon XL AT4 (cruise) grade braking?
dutchsea
We moved from a 2017 Yukon XL Denali to a 2024 Yukon XL AT4 (6.2L V8 GAS) and standard cruise control (not adaptive that we now no longer have) seems to work differently and I believe this is not correct, basically when putting the car in cruise control on downhill it's not keeping speed, but just picking up speed as it doesn't seem to brake on the transmission by downshifting (believe this is called cruise grade braking and is standard feature on all Yukon's). We also noticed that normal grade braking is not kicking in this I also believe is standard and get triggered when doing excessive braking on a downhill without being in cruise.
adamztrucking
It sounds like your Yukon XL AT4 is not engaging its cruise grade braking or normal grade braking properly, which should help control speed on downhill sections even without adaptive cruise control. Both cruise grade braking and normal grade braking are standard features on GMC Yukons, including the AT4.
Here are a few potential reasons this might be happening:
1. Transmission Settings: Make sure the transmission is in the correct mode. Some driving modes might behave differently when it comes to grade braking. Check if you are in a mode like "Tow/Haul," which tends to make these features more aggressive.
2. Brake System Calibration: Sometimes, the grade braking system might need recalibration, especially if it's not engaging when it should. This could be something a dealer needs to look into.
3. Firmware or Software Updates: There may be updates to the vehicle's software that affect cruise control behavior. It’s worth checking with your dealer to see if there are any available updates that address this issue.
4. Brake Wear: Though less likely in a new vehicle, if the braking system is not functioning optimally (e.g., brake pads are wearing unevenly), it could affect how the grade braking is triggered.
It would be a good idea to have the dealer perform a diagnostic to check if the cruise control and grade braking systems are functioning as intended. They can also verify if any system updates are needed.
Josejr00
