2025 LT vs Premier and HC
nomech
Senior Member
I've never owned a chevy SUV with MRC and/or air suspension upgrades, how much of a noticeable difference is there in ride comfort?
I've also done some searching on here and the general consensus seems to be, some people notice a big difference in ride comfort and some people don't notice much of a difference (comparing MRC and/or air ride vs 'normal' no MRC and/or air ride).
Like all things, there are pros and cons to both.
Can anyone provide feedback on their decision/thought process?
For example, if you have MRC and/or air ride, do you regret it (maybe it is too early to tell based on your vehicle purchase). I'm looking for feedback from newer Tahoes. Do the 21+ Tahoes all use the same MRC and air ride system? I live in the midwest where it does get very cold during the winter months. Of course I know these these are designed to work in colder climates, but I wanted to make sure I pointed that out.
I currently have a 2020 Tahoe Premier with whatever suspension ships on that car along with 22" rims and I'm not saying it is the best ride, but I'm fine with the current suspension.
That being said, I think I'm only looking at 2025 Premier and HC trims.
2024 White Tahoe
Senior Member
I have a 2024 Tahoe Premier 4wd with 20-inch factory wheels and MRC.
The ride is excellent. I’m sold on the MRC.
jerry455
I have a 2021 Suburban High Country with MRC and no air ride. I rides fantastic. I love putting the control to sport mode. It stiffens the suspension and steering and adjusts shift feel.
Antonm
We test drove a few different Tahoe's/ Yukons/ Escalades before buying our high country Tahoe. Both my wife and I could feel the difference and preferred the ride of the air suspension option, so that's what we bought (HC can be had either way, we specifically bought one with air ride).
Stinkyfurgeson512
When it bursts on the side of the road and the whole front of the car is bottomed out, remember, it's probably just a flat tire or any other mechanical issue, definitely not the air suspension :|
N
nomech
Senior Member
I did read that thread, I don't want that to carry over into this thread.
Antonm
Of all the problems this platform has (DFM lifters, engine bearings, NTHSA probe into engine failures, trans shifting issues, improper heat treat on critical bolts, etc.), frequent failure of the air suspension just isn't one of them (and every Escalade and most Denials have air suspension).
Air suspension is a proven tech that's been around for literal decades , pretty much every medium duty or above truck and 18 wheeler uses air suspension in some way. The 2013 Mercedes we bought brand new and traded in on the Tahoe had full air ride, that car had plenty of issues in the 11 years we had it, but the air suspension wasn't one of them.
If you're worried about air suspension breaking, then you should probably also have manual hand crank windows in your truck because the electric window can fail too leaving you without the ability to roll down the window. Same logic for power steering and power brakes, better take that crap off too because it can fail.
N
nomech
Senior Member
My local dealer only had two tahoe's and they both had MRC and air ride, I took one for a drive but the roads I took it on were very flat and smooth so I'm not sure that I would have noticed anything had it not been equipped with MRC and air ride. It was a nice/smooth ride, I just don't know if MRC/air ride had any help in that given the flat, smooth roads.
Antonm
We don't have that smooth road issue here in Texas at the moment,,, seems like very highway is under construction or being widened. So I drove through a bunch of road construction areas on my test drives (not really on purpose or anything, there was just pretty much no way around them if you wanted to get on a highway).
N
nomech
Senior Member
There are plenty of roads that are horrible in my area, but I limited my test drive to within a few miles of the dealership mainly because of a time restriction on my end.
SchneiderB1
