20x12 fuel hostage ?s
Hendo
ive done a good bit of searching and couldnt find anything..
will the 20x12, -44 offset 4.75bs hostage w 35x12.50 trail grapplers work with 6" of lift, or would i need to add keys and spacers too?
or would i be better off going with the 20x10 -24 offset 4.5bs hostage?
this is on an 04 awd escalade .
Max
Mile High
Denver
You'll need keys and spacers the 20x10s would fit better but you'll still have to trim to fit those. The trail graps run pretty wide in that size.
H
Hendo
thanks for the advice guys.
I think im just going to go with the 20x10's to keep the cutting to a minimum.
brucebruce45
I'd still gonna be cutting alot with only a 6" and 35s unless u get a full drop kit. Being ur esky is an awd I wouldn't be comfortable cranking it any more than necessary. Knuckle kits that are advertised as 6" are really a 4" lca drop and then 2" of crank to make up the rest
Max
Mile High
Denver
+1 on that do a pro comp full drop kit and see how she sits, the awd trucks are little bitches about being cranked compared to the 4wd trucks since the cv will always bind on awd trucks that are cranked to shit. I think a Full drop cranked up to a 7" would sit nice on 20x10s trimmed but you will have to sawzall some shit to get the clearance.
H
Hendo
Max
Mile High
Denver
You can delete the autoride but you still need the 51246 front driveshaft. Deleting is easy, just disconnect the battery for a few minutes and pull the RTD fuse under the hood. Then you can run bilsteins, ranchos, hell foxes if you have the loot. Hit me up if you need a kit built for ya.
H
Hendo
thanks for the autoride delete pointer!
here is the kit im likely going to purchase. its the only kit that i have seen that includes the front c/v driveshaft in the kit.
http://www.topguncustomz.com/Store/Gen2ProdDisplay.php?iview=198238626
Max
Mile High
Denver
Yeah that is the kit you want I sell em for about $1700 shipped with those shocks.
travishunter2016
