21 HC will need brakes before Summer
RST Dana
OH
So, my ride was in for service for a dead windshield wiper motor, which is a problem here in Ohio recently. Service guy did the normal inspection and reports brake pads will be needing replaced in the next month or so.
I normally perform my own brake maintenance, however, this ride has the fancy feature that reports pad wear in the display. Is that something that will work if I change the pads to....R1 or Powerstop Ceramic with driiled/slooted rotors? I have had both brands on multiple rides over the last several years with great satisfaction.
WalleyeMikeIII
Sunny and Snowy Minnesota
You just have to have pads that support the break wear sensor and a new wear sensor. Then reset when new pads are installed on that axle.
Would think the aftermarket has caught up to this setup by now. Or go w/ the Delco...always had good luck w/ those and they will have a design that includes the electronic wear sensor.
Note there was a period where the OE was using a softer material to minimize noise, but it wore faster (there is a TSB for this). So, depending on your driving, you may want to ask about the harder material if you do a lot of stop and go for durability...
Alphamods
