21 Yukon Screech from rear passenger side when turning, braking at low speed
CDD50
I have a 2021 Yukon short wheel base with 55,000 miles and I'm getting this screeching sound coming from what sounds like somewhere in the rear on the passenger side.
When making right turns or braking uphill at slow speeds, I get this quick loud nails-on-chalkboard/metal-on-metal sounding screech. It doesn't happen on every single turn or brake, but there's certain intersections that I can go to around my house and replicate it 100% of the time.
I found recall N212351031 - "Rear Drive Shaft Loss of Propulsion" which seems to describe my issue with similar symptoms. However I checked with a dealer and while the model, year and RPO code of my vehicle are included in this recall, my VIN turns up no recalls so they're telling me that this recall doesn't include my vehicle.
Any thoughts on this would be appreciated!
Big Mama
Virginia
I’m guessing the warranty is gone? Are your lug nuts tight? Pull the wheel off and look for anything loose. While it’s in the air check for play in the rear end and brakes and that shock.
Marky Dissod
When making right turns or braking uphill at slow speeds, I get this quick loud nails-on-chalkboard / metal-on-metal sounding screech.
Would you mind making a video of this?
I bet it will eventually be of help to others, not just you.
WalleyeMikeIII
Sunny and Snowy Minnesota
I’d still take it in. You have a powertrain warranty until 60k miles and 5 years. If it is rear driveline, will be covered. There was also a TSB regarding noise due to rust on the rotor face where the wheel attaches to the hub. Something is up, and if it is consistent, then worth taking it in.
Andreste22
