22 inch Tire Pressure
Knoxrower
I've searched but can't seem to find it. I had new 22's installed to replace the stock 17's. The installer (Tire Barn) set the pressure at 48 psi which I think is the max pressure for the tire. I've dropped them to 45 but I know they need to go lower. Anyone know what the door jamb says? Thanks
soulsea
Bar
The GM spec GY/Bridgestone tires have a 50 max psi ... I got mine set at 45psi.
Autbond
I am running 40psi with my 24's, if that helps. I would definitely recommend filling the tires with nitrogen, I am a believer after my 33x12.50R20 Nitto Mud Grapplers had 40k+ miles on them when I sold my lifted 06 4Runner and still had basically half the tread left.
repo58
Just installed 22" on my 2011 Tahoe, with bridgestone dueler ht 285/45/22 can any tire be filled with nitrogen? Also replaced 17" stock rim with 22" will speedometer be wrong? If so by how much?
14kvision
Repo can you post pics of your rims/hoe? I think I'm getting 22 inchers with the same duelers and curious to see how it looks. THanks!
domin8
Just Plinking
Highland Park, IL. Transplant from SLC, UT to redu
Yes, any tire can be filled with nitrogen, but I don't see why you'd want to waste the money. Look at the facts:
1) 70% of the air you breathe is nitrogen. The air compressors you use to fill your tires use the same exact air.
2) No nitrogen system that is used to inflate tires is ever 100% pure nitrogen. It just takes the air you breathe and tries to filter it. The most "purity" I've seen in a tire was 98%, and that was a new machine. Most machines record 95% or less.
3) Yes, nitrogen molecules are larger than oxygen molecules, but please see #1. Larger molecules due take longer to heat up, but they also take longer to cool down. Heating and cooling is what produces expansion and compression. All you did was slow down this inevitable process by filtering the oxygen and other gasses, and not by much.
4) It is said that the larger molecules of nitrogen help keep tires inflated better as weather temps fluctuate. Fact is, the size difference is negligable and not worth consideration.
5) My personal experience does include drag racing and slicks. This is the only place I noticed any real observable benefit to nitrogen. But, who heats up their tires at every light every day of the week only to sit 1-2 hours between each 1/4 mile run. Again, (see number 3) by the end of the day, if I went far enough in competition, my tires were only holding the heat instead of dissipating it. I found myself purging the tires, letting them cool, and refilling with air between each pass, the further I progressed.
Sent from my myTouch_4G_Slide using Tapatalk
K
Knoxrower
Thanks for the comments. I think I'll drop them down to 40 to soften the ride a little bit. It feels pretty stiff compared to the real soft 17's. I went with the Continetal CrossContact LX's. I wanted the Yokohama Prada's but they are out of production and tough to find at least in this area. I didn't care about the nitrogen either way. It was free so it really didn't matter what they put in them.
Anyone looking for 17's with about 2k miles on the tires?
hbr
Summerville, SC
I couldn't get the Paradas either in 22, going with the Bridgestones. Nitrogen is bunk....
BlackBettyBurban
