I've got a Tahoe RST on order and plan to buy new wheels, I'm either going to swap out the stock 22" wheels with a 22 x 9.5" +20 offset, or I'm going to get a 24 x 10" +25 offset. Not sure which I like the look of better, also if a 24" wheel results in a decreased ride quality then maybe i'll stay with 22".
If I go with 22" wheels I plan to just reuse the stock tires for now.
If 24" wheels i'm looking at possibly using a 285/40R24 tire:
Yokohama PARADA SPEC-X or PROXES ST III
Width: 11.7” 11.4”
Diameter: 33” 33”
Weight: 40lbs 43lbs
I'd like to use the 40 rather than 35 sidewall just to get a little more sidewall and possibly smoother ride, though i'm not positive it will fit, but from what i've seen on other 2021's it probably will fit.
My question is for anyone with a 2021 with 24" wheels did you notice a difference in ride quality? Let me know what wheel and tire size you went with.
Other question is for anyone right now with 285/40R24 tires on, any fitment issues and which brand?
Also does anyone know what any of the stock 22" wheels weigh?
Width: 11.7” 11.4”
Diameter: 33” 33”
Weight: 40lbs 43lbs
