26" KMC Brodie fitment
soulsea
Administrator
Bar
Mine has autoride, so do I have the same suspension as you? It is an LTZ.
Nope not the same ... the only hybrids with autoride are the Esky and the Denali. I have the same suspension with slightly different springs as the non LTZ Hoes and Yuks.
Autbond
Autbond
If the 28 fits then the KMCs will stick out 3mm more. Basically 1/8 of an inch if they have the same width.
So, then it is just an issue of whether or not it will look good with how far it sticks out? And how much it will rub? Other than that, it fits?
I really think these wheels would look good on a lowered 'Hoe. I have seen the 24" versions on a yuk, but they are available in +30.
protonvx
Pretty much any wheel with the correct hub bore and bolt pattern will "fit."
Depending on whether the truck is stock, lowered, or lifted is then the next issue.
Then wheel width/offset and tire diameter/width come into play.
If you want them to tuck, IMO you need +35mm or higher depending on wheel width and tire width.
My setup will tuck, 22x9.5 with +45mm on 305/40s.
Autbond
Autbond
Ok, I understand. Thanks for your reply!
EdwardsD
