26s on a 3/5 drop??
NeverSatisfied
eBay Baller
Wichita, Kansas
To all you guys running 26s and riding low how do u do it? Have a chance to put some 26s on my Tahoe they have 295/30 tires on them just really wondering if it would work? I'm ok if I gotta raise the front up a little the truck currently sits at 32" front and 32.5 rear any help would be appreciated
2001tahoefuentes
Passaic,NJ
I had 26s on my tahoe for the summer but with a 2/3 belltech drop i had 305/30 and had to do sum metal trimming up front it wasnt that bad only full lock turns i rubbed other than that it was great
NeverSatisfied
NeverSatisfied
eBay Baller
Wichita, Kansas
I know my front will have to be raised a little guess I may just have to do a test fit and go from there
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
my custom 3/5-6 kit
295 25 26
26x9.5 with 38mm offset
No issues
26x10 with 295 25 26 should clear also.
NeverSatisfied
NeverSatisfied
eBay Baller
Wichita, Kansas
my custom 3/5-6 kit
295 25 26
No issues
I'm not needing a new drop kit love my Mcgaughy's kit just wondering if these 26x10 with +30 offset would even be worth looking into
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
i was putting that as a reference. Your using spindles so front tires get pushed out a little so in front will prob rub a little
Knobz
Santa Cruz, CA
I'm rolling on 26's and it's not that's bad for being 26's and having rubberband tires. I have 255/30/26 tires which are perfect fit.
My setup is Belltech spindles, Belltech street performance shocks all the way around, uncut Z71 jounce stops, Tonys 6" springs, airlift bags, Spohn upper and lower 4-link bars, adjustable Spohn panhard bar, 3/4" bumpstops, free-travel mod, and I only had to do minor trimming in the rear, a little on the wheels well liners on the inside corners and then you sometimes have to cut the top shock bolt flush so it doesn't hit your rim… but for the most part it rides good and love my 26's
BigBodyBurban
