26s on a 3/5 drop??
NeverSatisfied
NeverSatisfied
eBay Baller
Wichita, Kansas
I'm rolling on 26's and it's not that's bad for being 26's and having rubberband tires. I have 255/30/26 tires which are perfect fit.
My setup is Belltech spindles, Belltech street performance shocks all the way around, uncut Z71 jounce stops, Tonys 6" springs, airlift bags, Spohn upper and lower 4-link bars, adjustable Spohn panhard bar, 3/4" bumpstops, free-travel mod, and I only had to do minor trimming in the rear, a little on the wheels well liners on the inside corners and then you sometimes have to cut the top shock bolt flush so it doesn't hit your rim… but for the most part it rides good and love my 26's
What kind of offset and how wide are your wheels?
Vigh_J
AB, Canada
I don't mean to hi-jack the thread OP but I have a very similar question and thought I would just post in here.
I too have a 3-5 drop and curious if 305/35/24 +18 will fit without issues.
EDIT**
Never Mind, Question answered. Sorry again OP
NeverSatisfied
NeverSatisfied
eBay Baller
Wichita, Kansas
The other thing is I don't want to have to run smaller tires than what's on there cause of some if the roads I have to go on
MeanGreen03
TX
my custom 3/5-6 kit
295 25 26
26x9.5 with 38mm offset
No issues
26x10 with 295 25 26 should clear also.
What 26" wheels have you seen with those dimensions?? It seems like the larger the wheel the less the offset. I've been trying to find some wheels with those dimensions (9.5" wide with ~35mm offset).....well besides billets.
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
custom 3 piece wheels and shaved mounting pad so more lip.
26x9.5 with 25mm-30mm offset with 295 25 26 will work also
swoodjr83
