26s rubbing??
saint777
i just got a 2007 black tahoe ltz...i want to put 26s kmc slides on it, but i want the best stance i can get with minimal rubbing...i am also going to lower the truck right ontop of the wheel..does anyone know what size tires i should be looking at and how much it will rub?
rosendo192000
I'm running 26" Zanetti's with 305/30/26 on a 3/2 Drop . I have some rubbing on u-turns and turns while backing up but that's it . It's not alot of rubbing either .i did cut out some plastic from the wheel hub , nothing that u could really see without looking in to it .
Before I even lowered it I was running the 26s with hardly any rubbing withOUT cutting anything .
Keanen55
HOUSTON, TX
You can always put a slightly shorter tire on the front. I went 295/30/26 on the front and 305/30/26 on the rear. The only thing that sucks is that you can't rotate them. Even with the 305/30's I didn't have much rubbing.
S
saint777
thanks for the input guys! i'll keep you updated with the results!
97ext
