285's on a 2017
TxJakeCA
BROTHER CAN U TAKE APIC OF FRONT BEHIND AND BOTH SIDES ?
AND WOULD 285 70 18 FIT ?
I believe a 285 would fit. The 275 doesn't rub at all no matter how much you flex the suspension. I was just scared to shell out 1200 and have rubbing issues without doing any body or suspension modifications. Hope this helps.
affliction4
Does it matter if the truck is 4x2 vs 4x4?
I had a 2015 2wd with a level kit and running stock size in these tires and had no issues. I would not run these on a non leveled 2WD as our current LT 4WD sits higher than the 2wd did stock.
riyadhali1413
Could a 2.5 inch level kit
Help me install 295/70/18
Like that silvarado 1500?
With minor rubbing?
*my ride 2019 yukon sle 4x2*
Yukon1689
California
Pretty sure I'm going to put on 285/65/18 on my stock suspension when I get new tires for my 2017 Yukon. Shouldn't be an issue because the Denali has 285/45/22 which is essentially the same size. The 275/70/18 does intrigue me though...
Yukon1689
California
Which did you end up going with and do you have pics?
