2nd passenger carpet wet
El_Callao
Cleaned the Suburban today and when I took the second row passenger mat out I found the carpet was wet on the passenger side. I pulled the trim and didint notice any leaks or signs of leaks. The insulation underneath the carpet is totally saturated and the carpet smells like mildew but only in the passenger leg bay. What would cause this? Everything around that area is dry.
Underneath is the exhausts meets the tail pipe above that is the exhaust shield I have no sunroof and rear ac line drains great what could it be
E
El_Callao
Check to see if your roof rack is leaking.
Noticed it could of been my rear ac clogged drain cause it was draining from the ac lines but once I released the clog water just came out.
Cause its running from my rear to the front
Also the 2nd row passenger seat floor gets very hot that my oem floor mats have condensation on them
dabsnabbs
