3/5 DJM with 24's
N
Nelson
Hey nelson with the 3/5 kit do you have any rubbing issues? i have the same size tire as you and im about to drop my xl im still debating between 2/3 or 3/5. thanks
No rubbing.
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
also if you need it to sit lower you can cut the coil at very bottom right off to the big portion and it will still be fine MAKE SURE THE CUT PART SITS UP TOP ON THE FRAME the part that sits on the axle do not cut. you will get another 1/2 to 3/4 inch and will ride fine
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
The white truck i posted has the 3rd row in the rear plus 2 13 w7s in a big mdf box and its fine. He has the djm shocks though so I cant say how you will be on other shocks since I know many of them are softer than the djms.
if you cut the bumpstop brackets off in rear plus use djm shocks/rear hardware kit try that out before you spend money on the helper bags.
Nickleahy23
Portage/Menomonie, WI
sounds good..most likely i will end up with the djm shocks since im gonna do that whole kit for $825 which comes with front/rear shocks, arms, rear relocation kit and coils correct?
I just dont want to run into issues over the summer..my sub and box weighs around 150 lbs, 40 for the amp, 60 for the battery, plus i have 5 people in the truck quite a bit..
how much are helper bags for those TB springs? i have them in my djm coils right now, but i heard they are different?
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
helper bags are 75 on amazon. 4.5 wide by 6 inches tall are bag size
ghost
Senior Member
are you talking about cutting the tb coils NORCAL?
super_kev
