3/5 drop - not quite
matt14
san leandro,ca
When i first installed the kit, the rear sat lower then the front. I cranked on the keys all the way to where it was hella low in the front. Then re-adjust the front till it was even with the rear. Still bullshittin and havnt re-adjusted the front now that the rear is a little lower (tb springs)
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
hey matt what you sitting at 33 from ground to fenderlip in rear? 305 40 22 right?
Physh1
Ok...measured my truck this evening...
- 3/5 delux kit from NorCal...
- I've only driven the truck to the alignment shop then home...50 miles on drop so far...
- Hard as hell to find a flat piece of ground here. The ground sloped down to the driver side a little...so these numbers may be off a little...
- Truck is sitting on 285/40/22 rubber...
Driver Front = 32" 33" = Pass. Front
Driver Rear = 32.5" 33.5 = Pass. Rear
These measurements are with the rubber isolators installed on the rear coils. The driver key bolt is still in the "factory" position. The passenger side key bolt was backed out ~3/4" to get it somewhat level.
How do these numbers look?
Cameron
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
lift the drivers side it will bring pass side rear down.
Physh1
For driver & pass. side should I target ~32.5" for the front & ~33" for the back?
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
what size tires are you on again? with 305 40 22 i got matt14s at 32.75 in rear
Physh1
285/40/22...I do have the isolators on too...
I'm not bugged by the rake front to back...more so just getting the pass side to get down even with the driver side.
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
yah he was on 305 40 22 and its at 32.75 and i run no isolators on any of the tb spring set ups its not needed.
Physh1
Ok...after I drive it a little more and things settle in I'll mess with the keys to get the front level...
CoyotesRUS
