3 rca outputs with a Radio with only 2 rca outputs
ladorn45
Hey everyone,
just trying to get some of your knowledge and wisdom on this topic. So I have a radio that has 2 outputs one front and one rear that is switchable to sub (allowing me to have sub control). My question is can I use the rear rca as a sub out and then get a line converter something like the link below in order to achieve 3 amp output. Will the quality from the converter sound like crap never used one before or is this just a waiste of time.
http://www.caraudiogiants.com/kicker...FYcehgodmzcApg
ISU-152
What amps are you planning to use?
L
ladorn45
Current set up Below (fyi its all older gear but still sounds great). Also if the line converter sounds like crap. The other option was to just run a rca from the new radio rca out to the alpines rca in and call it a day. The current alpine is located in the cd try in a 2001 tahoe and the new radio would go where the original radio went
Current radio
Alpine cda 7875
New Radio
https://www.amazon.com/gp/product/B01G3LE5R8/ref=oh_aui_detailpage_o00_s00?ie=UTF8&psc=1
Amps
Rockford Fosgate power 550X 4 channel amp
Memphis 1000 Watt Class D Amp 16 ST1000D
ISU-152
So why do you need 3 outs? Rear/sub output to subs and front output to the 4 channel....done
L
ladorn45
Cause i tend to be overkill on things if i split the front to front and rear on amp i know i wont have fade controls but is there a considerable loss in audio quality
ISU-152
You won't have fade controls anyways with one out running the sub. There's a million ways to split an rca but if you want full control via the head unit and not just tuning your amps....get a new HU with 3 outputs. Pretty cheap these days.
L
ladorn45
Yea i went with this unit cause of the andriod features and a unit with three amps out is like 200 more. I figured ill just split the rcas and if i notice a downgrade quality i can keep the alpine in and use it as a processor
You can just use a Y splitter for the front RCA's.
treehan77
TYF Fiend
Crestview, FL
Does your sub amp have a port for a sub control? If it does, just use the rear as rear, split it and add the little level control knob for sub
His rear can be switched for sub out, which is just low frequencies. He could do it that way but then he won't have sub control from the head unit.
Steven94
