3 way connector for LED/fog wiring
4WDTRK
4WDTRK
sleeps in garage
Socal dreaming of Norcal
Fleece's All-High board would turn your lows on with your highs, as well as your fogs, even if they aren't already on. You can also solder an extra tab on the board to provide a trigger for a relay to run to your light bar. All you have to do to be able to NOT run the light bar whenever you flip your highs on is to interrupt the signal to the relay, by means of a switch inside the cab.
I have the Fleece board, and love it. I have my 32" light bar pulling power directly from my battery, but my switch is independent of the high beams.
First I've heard of this All-High board. Thanks for the info I'll do some searching on that mod. I'm getting pretty stoked to geek out on this upgrade!
BigDaddy13440
Rome, NY
In the Electronics Section, Jdpber has a sticky at the top for the All-high mod... the board, shipped to my door, was under $25, and literally takes less than two minutes to do.
4WDTRK
4WDTRK
sleeps in garage
Very cool! Thanks for the heads up, I'm ordering for sure! I saw the 4 on hi mod a while back, but really wasn't into the jumper thing. I like the clean and simple chip.
damitchell
Please document your steps and PICs when you do this project. Would be a great DIY guide.
mecanico448
