305/35/24 07+ cornering kit: how to fix the rubbing
Deephaven
I've got a set of the TBSS wheels on my Escalade. They rub everywhere. Nasty in the back. Looks to me like a spacer to kick them out a bit in the rears would help a ton. Front I am not sure what to do.
I searched, and couldn't find the fix. Figured others may need it as well so I'd make a thread and ask.
Here is the truck:
The fronts start to rub about halfway to lock. The rears rub if you make the ass swing at all. How do you all modify the wheel wells?
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
In rear will need to trim plastic thats normal.
front will need to do my feneerwell mod. 2x4 and turn sideways and turn tire this will push it against rear well pushing the metal back which gives more clearance.
Deephaven
Deephaven
Anyone have any pictures of the process? Before and afters?
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
Here just have it about 5 inches longer than edge of fenderwell snd guide it while someone turns tire
Deephaven
Deephaven
Awesome thanks. Never damaged a fender that way? I was timid when I tried
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
No I run it 2 inches longer and it will pull it inside the fender and be cool
Jonah52
Senor ******
Cleveland
This thing looks so good. Does it ride better than stock? Did the handling kit firm it up?
Glenn54
