35" tires
TahoeTaz
Jersey
I did mine to deal with snow. I have stock 3.43 axles, so I'm not trying to do anything to challenge it anyway. Rims will be later in the upgrade process... after the axles get upgraded, and the bodywork/paint is done. I've never run mine w/ low psi to have to worry
the big blue bus
richmond, va
heres mine with 315s 3inch body lift and 2inch block in back fronts like inch lower. they measure 33 though cuz like no tread on em
josh the people
hey big blue i really like the lights u got on top of your Tahoe what are they called so i can look some up and order them for mine!
Dlong30
Shreveport, LA
i would definitely listen to these guys. they know what they're talkin about. I was in the same boat as you. i ended up goin 3" body and a crank. cleared 295/70r18 but shows a lot of frame. this is just a bandaid fix til i get the $ up for a full 6" lift. but seriously- dont get the 2-3" lift. best of luck!
McLovin
there she is t-bar crank with 35s on stock rims with no rubbing
Hi Alex,
i have 3 questions:
1) when you complete turn your steering, do the tires rub on the frame?
2) what blocks are you using in the rear (maybe a link)?
3) are you using any wheel spacer to prevent framerubbing?
Thank you.
Y2KpewterZ
Holy stuffage. Looks tough though. And for the record about skinny wheel/wide tire and low psi.. im running a 37x12.50 wide tire on a stock 17x7 (maybe 7.5?) wheel on my F150 and I air down to 12-15 psi in the OBX's sugar sand with no problems. I even ran a 12" wide wheel on a 12.50 tire no problem. Although the first is least likely to pop a bead (skinny wheel/wider tire)
YukonandtheHOE
Sorry to revive old an old ass thread but this is the first hit on google...
Yes, 35's will fit on a bone stock OBS Yukon with just a 3 inch body lift.
Had some new Super Swamper M16's 35x12.5r20's kickin around and my Tahoes factory rims doin nothing.. so i paired them up and ordered up a 3'' BL for my 500$ winter beater Yukon, threw it all together today.. just had to chop the corners off the bumper like all my 4x4 OBS's with 35's.
jerryjoe28
That Guy
cabot AR
good looking ride - how close are u when u turn all the way one direction?
YukonandtheHOE
I got about 3/8's from the fame lock to lock. its gonna rub a little when shes cranked all the way to one side and the suspension flexes but on flat surface i have 100% turning radius. Left the torsion bars alone too so it still rides half decent. I have a k2500 if i wana drive a lumber wagon haha!
Levi0320
