3rd row seat power fold motor fix?
ReaperHWK
2015 Tahoe LTZ.
3rd row power seat stopped working (the 40 of the 60/40). It was stuck down and I hear the motor working. Looked at the cables and everything looked intact, the motor wasn’t pulling the cables. Removed the seat and now it’s in the garage.
Looks like I need to remove the seat cover to get to the motor and see what’s going on. To me looks like the motor is not connected to the cables, either snapped cable or not connected.
Anyone replace the motor before? Can I even buy this part separately? I looked on YouTube no videos I can find of a motor replacement within the seat.
Any help would be appreciated before I blindly start taking the seat apart.
ReaperHWK
ReaperHWK
I found this so looks like I can replace the parts. Good news I thought I may hav work buy a whole new seat!
ReaperHWK
ReaperHWK
IMG_1649.jpegMessed with the seat a little. Was able to get the seat cover off and if you flip up the foam you will see the actuator that controls the release cables. The motor that actually moves the seat is behind the seat and uses a sprocket attached to the metal seat bracket to move the seat. It’s supposed to work by the cable actuator first pulling the cables to release the latch, then the motor moves the seat(there are actually 2 motors, one for moving the seat and one for releasing the cables). Tried to get pics of them both.
I’m going to hook this up to the car tomorrow and see which motor isn’t working. I believe the cable actuator motor is FUBAR and the seat motor is still good. I could see the motor trying to move and it would actually deflect the metal in the bracket.
That sprocket above actually should go into the black bracket but I had to separate them because I can’t move the seat open and close with the motor jammed in there.
ReaperHWK
ReaperHWK
Hello, my right seat is stuck in the almost upright position. I can hear it trying, but won’t budge. What part needs to be replaced.
#11 in the diagram. That releases the seat locks. If the locks release and it doesn’t work it’s the motor, #12
hgonzalez
Hello. I i’m currently going through the same situation for 60 portion of the 3rd row seat. Its stuck in the down position and I could see and hear the motor trying to move but it’s not releasing. I also see both the cables slightly move, but no dice. Did you figure out exactly what was wrong with it and do you know the part number for that actuator that releases the seat? I did manage to pull on the black tabs that hold the 2 wires and the seat released about 5 inches with so now it’s stuck at an angle. Next I will be removing the rear storage box to get a better angle on those tabs so I can at least get the seat upright for now.
I had been experiencing intermittent problems with this seat, not wanting to go up or down, every so often in the past few years now it just don’t come back up.
ReaperHWK
ReaperHWK
Yeah I fixed this a long time ago. Number 11 in the diagram. Go to tasca parts website or some other online GM parts dealer and you can find that diagram and it will show you what PN to buy.
You need to remove the seat from the car, and remove the seat cover and foam. Then you will see the actuator and it will be fairly obvious how to replace it.
Since your motor is trying to move the seat id say your issue is the same as mine was. The seat release actuator is broken. That’s #11 in the diagram.
Acts822
