4/6 drop on z71
cb450r
Hi all, been on this site for a bit but don't really post until now. I have purchased and am in the process of installing Tony's 4-5/6 drop kit along with the spohn kit.
So far the install has been pretty straight forward with only a couple minor snags. I finally was able to button up the rear of the truck after receiving my energy sway bar bushings but I have questions/concerns for those of you that have this kit or the relocation kit for the bar. I have maybe a 2mm gap between the passenger side shock and sway bar. Is this normal or am I missing something here? Seems like it will most def hit when driving the truck. Also the relocation of the driver side mount seems like it might be unstable sitting halfway in the round indent of the spring pocket. Any insight I on these issues? I'll get photos and keep you all posted on progress if you like.
NathanJax
Vacation Nathan
Administrator
Jax, Fl
normal... it's a VERY small gap, but mine does not hit.
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
when the truck is on the ground it clears fine. You have nothing to worry about and wont hit the shock.
partswapper
