4 HI mod
02TahoeMD
somewhere on the road
It may be easiest to pull the drivers side headlight, unplug the bulbs, and then physically trace the wires back from the bulb until you find an ideal location to do the splice and mount the relay.
I did this on my 02, using the Painless Wiring kit, and I know they changed the wiring after that year, but anyway, I did the entire kit just under and behind the headlight assembly. Everything tucked away nicely and you cant tell it is there.
blueflamed03
blueflamed03
Oklahoma
thanks, yea, this one goes back to fuse box under hood, so wasn't sure if it went before fuse box, or after....instructions aren't too specific.
Well Worn Chevy
