Hey guys, just alittle explaining and then question
I have a 99 Yukon z71, I CANNOT get the 4x4 to fully engage, I have replaced the transfer case and know that’s working strong I’ve replaced the motor on the differential and just today 2/19 replaced the front diff and now…still nothing, off the ground the front tires will spin but not strong but on the ground freakin nothing still
Now my question is, I have a wire ripped out of the front hub assembly so no abs oh well so would that be causing that to not work as everything else works, mind you I can hear that motor on the diff move smoothly
I could really use you help as I’m about to run it of a bridge thank you in advance
