4 wheel drive
Big Mama
Virginia
No worries. It’s super easy. No special tools and usually no need to jack it up. YT has tons of videos. If you’re not comfortable doing it your oil change place can do it in 5 minutes.
vcode
I’m thinking 4wheel hi, it doesn’t have a distinction between the two just has an ⬆️4
Should be 3 settings? 2wd Auto and 4wd (what you show). You should not drive on dry pavement if you are in 4 hi as anything but a straight line will cause driveline binding as the transfer case is locked. You will also get more noise as everything is locked and spinning as well.
NELLY1947
To be sure...front and rear diff. Transfer case...trans mission oils are good.
When u put it in 4 A - 4 L - 4 H.
You have so many things working it's just amazing how all keeps in sync. I know this might sound dumb but your tires are all the same size with about the same amount of tread wear
Kira4454
