4L60 park pawl, not ingaging while "flexed out"???
bansil
East TN in the MNTS
So just came back from the garden, and there is a steep offcamber climb into the field, 4 low just creeped up no issues
coming back down I was in 2 hi and decided to stop and grab a picture of the rear flexed out
went to put it into park, let off brake and it slowly rolled forward; so I hit the brakes, tried again from 2nd to park...slow roll, the park pawl wasnt engaging
so I proceeded and got onto "level" ground still fairly steep and park engaged like normal???
So I said WTF and put it into low range and creep backwards until it was twisted up///no park
is this designed to not engage so the pawl doesnt get broke off if people dont apply parkbrake first>???
very weird, just curious
Thanks
Chevy305
Most likely being flexed out pulled your shifter cable out of adjustment and it wasn't fully in Park. Otherwise in a situation like that, NEVER trust your Park pawl. Always use your parking brake.
B
bansil
East TN in the MNTS
okay that makes sense: I wasn't in a bind (due to wt) so I didnt set park brake
weird thing is it didn't "ratchet" like old TH350/TH400 it just creeped
I will look into the cable and it's attachment points to move or loosen them
it was weird, indicator went to P (cable driven) tranny didn't go into Reverse
(actually "flashed" converter to check that)
I will check cable
Thank you, something I did not think of...Cheers :cheers:
Capeles
