4WD Issue
intlhouseofdan
Hello all, new to the forum. I bought a 97 Yukon about 3 weeks ago and I noticed that the 4WD switch acts funny at times and will not respond. I cant quite isolate it but I am wondering if it has something to do with heat. When I run the truck, most of the time 2HI is lit but every now and then, it is lit so dimly that I have to cup the switch with my hand to even see it. When I hit 4HI to test it out, the 2HI light goes off but then comes right back on (still dim) after I depress the 4HI switch. I can find all sorts of information on blinking lights but I haven't been able to find info on a dim/unresponsive switch. When the switch works normally though, it seems to engage just fine.
Any ideas?
Thanks,
_IHOD
Donnie Yukonie
Yates Caretaker
its probally just bad bulbs in the switch or a short in the bulbs , now when you said you press 4 hi and the 2wd light goes off and back on can you feel the truck lock into 4wd?
I
intlhouseofdan
Hey thanks for the reply.
Nothing happens when I hit 4HI besides the 2HI light going out while its pressed, the only time it responds is when its at full brightness. Funny thing though, if I give the switch a hard tap, the light brightens up again and all is well. I am thinking that something is loose.
Donnie Yukonie
Yates Caretaker
well lights or not it should still go into 4wd im leaning towards a bad switch atleast i would start there , next would be the actuator but check to make sure no wires are cut or loose and check fuses
Donnie Yukonie
Yates Caretaker
well before you buy the switch see if you got power to the switch using a voltmeter
tyet
